Jump to content
Denon AVR-3300-no sound from sub...HELP!!!
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   RichB
RichB
    Extra
  • 21 posts
Posted August 21 2003 - 06:10 AM
I just had my HT setup re-installed and I can't get any sound from my sub whatsoever. I have a Boston PV-600 ( I think that's the model number) and I have a Denon AVR-3300 receiver. I seem to remember having trouble the first time I set up the receiver, but I can't remember what the solution was. I have the Receiver settings set to subwoofer-yes and LFE. Any ideas?
#2 of 6 OFFLINE   Jack Briggs
Jack Briggs
    Executive Producer
  • 16,727 posts
Posted August 21 2003 - 07:08 AM
Just in case: Have you checked the connection between the Denon and the subwoofer to make sure it's securely in place? And, assuming the Boston Acoustics sub is a powered unit, is its amplifier switched on?
#3 of 6 OFFLINE   RichB
RichB
    Extra
  • 21 posts
Posted August 21 2003 - 08:21 AM
That was it. Loose connection. Thanks! Now any advice on setting the crossover frequency and LFE as opposed LFE+Main?
#4 of 6 OFFLINE   Lewis Besze
Lewis Besze
    Producer
  • 3,134 posts
Posted August 21 2003 - 08:51 AM
Depends what speakers are used for the 5 main channels. In most cases 5 small+sub on is the best.
#5 of 6 OFFLINE   Chuck Kent
Chuck Kent
  • 983 posts
Posted August 22 2003 - 12:37 AM
LFE+Main is a subwoofer mode that sends both LFE from sources that have it (5.1/6.1 DVD, sometimes satellite and digital cable if they have 5.1) and the bass that goes to the front mains if they have been set to "Large". The 3300's crossover is 80Hz so IMO, you don't want to set the sub's crossover any lower than that. IMO, I'd set it at it's highest setting or turn it off (If the sub allows.)
#6 of 6 OFFLINE   Dave Miller
Dave Miller
  • 854 posts
Posted August 22 2003 - 01:16 AM
Once you've got those settings done, there is also an LFE volume setting for both DD and DTS modes that are accessible from the menu system on the AVR-3300. Make sure those aren't set on -10 or something so low, you can't hear the bass. Peace, DM
"We all end up dead, the question is how and why."
