Jump to content
Sign up for a free account!
What guage Power Cable you running?
8 replies to this topic
#1 of 9 Scott L
Scott L
    Producer
  • 4,466 posts
Posted August 01 2003 - 09:36 PM
In my old car stereo I first had one 4-channel amp using an 8g amp kit. Later I added a 10" sub and simply another 8g cable isntead of a single 4g. Just found it easier this way and research told me it would work fine, as it did.
I'm gonna be buying a used 240sx or Maxima in the coming weeks and I was wondering what size cable to start off with. I want to go much further quality-wise this time using Focal components, RF amps, 2 12"ers, and an Alpine HU with at least 3 4-volt preouts. Will 4AWG be enough or should I go bigger?
#2 of 9 Diallo B
Diallo B
  • 1,075 posts
Posted August 02 2003 - 03:52 AM
I would go with the 4 gauge. You could go 2 or higher but at that point you are asking for install trouble when trying to run that cable through certain points of the car and under the carpet and such.
Run a line of 4g from the battery to wherever you amps are going to be and put the 4 gauge into a 2 or 4 point distribution block. Then if you want to expand again you simply have to run a line from the distribution block versus running a whole separate line. Make sure that the distribution block is capable of holding 4g cable though.
djb
listen with your own ears...
watch with your own eyes...
make your own decision.
_______________________________________
#3 of 9 Leif Wall
Leif Wall
  • 405 posts
Posted August 02 2003 - 06:46 PM
I run 0ga. from my battery to a distrubution block. From there it splits into 2 4ga. to my two amps.
#4 of 9 Jeff_Krueger
Jeff_Krueger
  • 122 posts
Posted August 04 2003 - 09:39 AM
I have 4awg, split off into a distro block with 8awg to 2 amps. Though what I have is sufficient, I wish I had run 0awg just for the potential of upgrades.
#5 of 9 Geoff L
Geoff L
  • 1,702 posts
Posted August 04 2003 - 01:04 PM
How thick/big around is high strand count 0-gauge cable?
Curious
~{ Speak of what you know, listen to what you don't.! }~
#6 of 9 Leif Wall
Leif Wall
  • 405 posts
Posted August 05 2003 - 11:41 AM
Geoff - I'm not exactly sure on a strand count. Could probably find the info online somewhere. My friends usually refer to it as a garden hose if that gives you an idea. Posted Image
#7 of 9 Roger Dressler
Roger Dressler
  • 187 posts
Posted August 22 2003 - 08:35 PM
I just ran a 4-ga ultraflexible link in my '91 Maxima to the trunk. There is splits to 2 of the 4-chx60w Sony amps and a 200W sub. Seems perfectly adequate.
Roger Dressler
#8 of 9 Scott L
Scott L
    Producer
  • 4,466 posts
Posted August 23 2003 - 03:42 AM
I finally ordered my parts online and did some more research. I'm going with an 8g for the 4-channel amp, and a seperate 4g for the sub amp (it'll be powering two 12's).
#9 of 9 Ryan_C
Ryan_C
  • 375 posts
Posted August 25 2003 - 02:09 PM
I've got 1/0 gauge running to a distribution block, then 4 gauge running to my two amps. And the phoenix gold 1/0 I have is about the size of a quarter.Posted Image
Youth would be an ideal state if it came much later in life.
