Brian Mixon
- Jul 27, 2003
This could very well be a stupid question, but ugh im just wondering...if a tv has component inputs does that mean it will run in progressive scan through the right dvd player? I bought a used 60" sony projection tv. I think its about four years old.
I have no manual and cant think of a way to tell for sure what its capable of in high definition.
Also on another topic I was thinking about getting a dvd player with a DVI connection.
Although im pretty positive I cant have a DVI-D connection(digital to digital). I believe I would need a digital to analog connection. And im very curious to find out if in that form of connection, is the picture still by far superior? Or is it just a minor upgrade over analog to analog component connection?
I myself figure no matter what DVI connection I use, it would be a better way to go. Ecspecially if my tv isnt progressive scan capable. Due to the fact that I would be able to atleast play the dvd at 1080i resolution...right?
Please feel free to set me straight if it sounds like I heard somthing wrong.
