Jump to content
which rg6 for making component cable
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   buster _bb
buster _bb
  • 13 posts
Posted July 22 2003 - 07:23 PM
i am going to have a go at making a component cable can get 2 types of rg6 one has solid copper core double shielding the other is steel center with copper coating but is quad shielding which would be better thanks
#2 of 6 OFFLINE   Chu Gai
Chu Gai
    Lead Actor
  • 7,270 posts
Posted July 22 2003 - 11:58 PM
Thou shalt not use copper plated steel unless you are exclusively passing signals above say 50 mHz only. Above that frequency the 'skin effect' becomes dominant and the majority of the signal rides the surface of the conductor. Hence, steel, being cheaper than copper, is used. A penny here and a penny there and several billions of feet later and you're talking real money! If your lengths are short, a few meters, then you could substitute RG59 which has a smaller center conductor and this results in a lighter and more flexible cable. Since your signals are well below that number it would dictate that 100% copper, stranded or solid, is the right way to go. BTW, if shielding is a big thing to you, I'm sure you can find quad shielded copper over in australia.
#3 of 6 OFFLINE   Bob McElfresh
Bob McElfresh
    Producer
  • 5,183 posts
Posted July 23 2003 - 02:33 AM
Buster: Can you find out the frequency response (sometimes called "Attenuation") for that coax? Like road-surfaces, they are built for different speeds. The CATV stuff works for radio-frequency signals, but not so good for video, or HD video. Here are the common max frequencies. You want a coax that will handle 3-4 times this max frequency to handle sudden changes: Component Video: 4 Mhz. Progressive Video: 13 Mhz. 1080 HD Video: 35 Mhz. So you want a coax that will handle 4 x 35 = 140 Mhz. Look for a coax that has a 3 db drop somewhere above 140 Mhz if you are building cables for HD video.
#4 of 6 OFFLINE   buster _bb
buster _bb
  • 13 posts
Posted July 30 2003 - 07:56 PM
has anyone tried canare cable i can get it in aus
#5 of 6 OFFLINE   Chu Gai
Chu Gai
    Lead Actor
  • 7,270 posts
Posted July 30 2003 - 11:13 PM
Canare is fine too. Just about any, I do mean any, solid or stranded copper RG6 or RG59 is going to be vast overkill for running signals from your DVD player to the tv or for that matter into the receiver to take advantage of switching capabilities. Realistically, it only starts to matter when the lengths get upwards of a few hundred feet.
#6 of 6 OFFLINE   Andrew Pratt
Andrew Pratt
    Producer
  • 3,813 posts
Posted July 31 2003 - 06:07 AM
[quote] Just about any, I do mean any, solid or stranded copper RG6 or RG59 is going to be vast overkill for running signals from your DVD player to the tv or for that matter into the receiver to take advantage of switching capabilities. Realistically, it only starts to matter when the lengths get upwards of a few hundred feet. [quote]
Chu is that also true for Hi Def as well?
