Jump to content
Coaxial and analog hookups?
1 reply to this topic
#1 of 2 OFFLINE   Paul Powell
Paul Powell
  • 6 posts
Posted July 08 2003 - 05:28 AM
I'm installing my HT and the manual is very unclear about one detail. From my DVD player do I only run the coaxial cable for sound, or do I run both the coaxial and the analog (RCA)? Will I get both Dobly Digital and Pro Logic with just the coaxial?
#2 of 2 OFFLINE   Jake K
Jake K
  • 132 posts
Posted July 08 2003 - 05:44 AM
Only coaxial is needed, unless you are referring to DVD-A analog outputs, which would need to be connected to play DVD-A disks. But if you are just talking about the stereo outputs, then no, it is not necessary. You might want to make sure all the settings are set to allow everything to be sent over the coaxial connection.
