Jump to content
Need Help calibrating...
  • Please log in to reply
7 replies to this topic
#1 of 8 OFFLINE   MarcWi
MarcWi
  • 44 posts
Posted July 03 2003 - 04:20 AM
I finally got a level meter (Theya re on sale at RS this week!) Anyway, Im using the ovation disc form best buy, and heres my dilema: Calibrating dolby, DTs, or the receiver (Pioneers VSX-D811s) all give me different settings. I don't know which to go by! Any advice here.... Thanks...
#2 of 8 OFFLINE   ChadLB
ChadLB
  • 1,523 posts
Posted July 03 2003 - 07:08 AM
Read the following:
http://www.hometheat....553#post650553
#3 of 8 OFFLINE   MarcWi
MarcWi
  • 44 posts
Posted July 03 2003 - 08:37 AM
Thank you and I had read that. However, using the method it recommends, I find the settings are different depending on which test I use. Which is the one to go by? In other words, if I calibrate to DTS, it is off for Dolby. If I calibrate to Dolby, the other is off. Lilewise for the systems own test tone genrator.
#4 of 8 OFFLINE   ChadLB
ChadLB
  • 1,523 posts
Posted July 03 2003 - 08:47 AM
When you say off what do you mean by off. I use the Sound & Vision one and for DD my receiver volume is set at -27 and DTS -32. All speakers settings end up being the same for both DD/DTS. Don't worry about using the Receivers test tone. Use the disc...it is more accurate for DD/DTS then the onboard test tones. Any questions let us know. DTS movies are about 4db higher than DD movies..
#5 of 8 OFFLINE   MarcWi
MarcWi
  • 44 posts
Posted July 03 2003 - 09:02 AM
Maybe Im crazy or doing something wrong, but to me it seems that the speakers volume relative to each other is different depending on which test I do.
#6 of 8 OFFLINE   MarcWi
MarcWi
  • 44 posts
Posted July 03 2003 - 09:22 AM
Further testing leads me to find that on DTS the rears are louder thatn on dolby....
#7 of 8 OFFLINE   Bob McElfresh
Bob McElfresh
    Producer
  • 5,183 posts
Posted July 04 2003 - 02:49 AM
[quote] speakers volume relative to each other is different depending on which test I do. [quote]
The problem is the test-tones use slightly different frequencies and your speakers produce different volumes for the two.
Audio is complex. Can you pick 1 frequency to be the 'reference' when adjusting your system? Of course not. You have tweeters, midrange and woofers, each better at some frequencies than others.
So test-tones are a random-static mix of sounds that try and shotgun all the drivers in your speakers. But the receiver, the setup disks each use a different "random" selections of sounds which produce different results.
The answer is: pick one, use it, dont worry about the other tests.
As long as all your speakers are calibrated with the same test, you have level-adjusted your system with the same source.
#8 of 8 OFFLINE   MarcWi
MarcWi
  • 44 posts
Posted July 04 2003 - 03:36 AM
Thaks for the advice!
