Jump to content
Sony DVD Dream System DAV-C770 for $310.99 AR
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   DarrenChan
DarrenChan
  • 7 posts
Posted July 01 2003 - 06:25 PM
http://www.sonystyle...._WB06&Dept=hav
How is this audio/dvd system? I'm going to start building my first home theatre and was wondering if this was decent, probably not for you hardcore folks? Posted Image Epinions had some decent reviews of it...
Heard the DVD changer is slow, but I can always replace that, any recommendations? Any other sets I should look at? For my first home theatre system, I'm not sure if I'm knowledgable enough to buy everything in pieces, so I may be buying sets for this first one...
#2 of 5 OFFLINE   DarrenChan
DarrenChan
  • 7 posts
Posted July 02 2003 - 04:11 AM
NM, looks like it is a pretty terrible system, even at that price.
#3 of 5 OFFLINE   Russell Osborne
Russell Osborne
    Extra
  • 22 posts
Posted July 02 2003 - 08:07 AM
Darren, There is a vast wealth of knowledge within this forum.Perhaps you could post a question(s) that is more specific that includes your budget,room size ,intended usage ( ? %=movies / ? %=music ) and maybe room dimensions. There is a home theater system for most every budget. Depending on your goals for your system and how critical your ear and armed with information stated above,someone can recommend a system be it budget or high end that could save you from buyer's remorse. Recommendations vary and are only just that . Finally ,if you dont want to get into all that and really just want to know what I think of the system then I think it is ok for the money. It will sound fantastic at first especially if going from tv speakers to this but alas,the bug sets in and the $300-$400 bucks you spent could have gone towards something a little more satisfying long term .Sorry for the length of this I'm truely just trying to be helpful.
Rolling Stones !!!!
#4 of 5 OFFLINE   DarrenChan
DarrenChan
  • 7 posts
Posted July 02 2003 - 12:11 PM
Thanks, I'll do that, I posted a thread like that on the AVS forums, but didn't think to do it here as well. I'll just link to it when I'm done posting. Thanks again!
#5 of 5 OFFLINE   DarrenChan
DarrenChan
  • 7 posts
Posted July 03 2003 - 09:42 AM
http://www.hometheat....67#post1636167
