Wade.Pe
- Jun 30, 2003
Hi all. I had a bit of a browse around the forum yesterday and was very impressed. Clearly there is a lot of knowledge out there.
I was hoping some of you may be able to provide me with a little advice.
I'm moving from the UK to the US shortly, so none of my existing electronics are going to work. Even if they did, my TV and sound system at the moment are very low end, and it seems like a pretty excuse to buy new stuff anyway
Whatever I end up getting needs to sound good, look good, and be reasonably simple to set up and use. I would also prefer something that is discrete (small speakers etc). I'm happy to spend around $2500, but if I found a system that does all that for bit little more or less, thats OK too.
Until yesterday when I started doing some proper research, I thought the Bose Lifestyle 35 may have been a contender - it also has a 'dual voltage' option which would mean I could take it with me when I head back to the UK or Australia.
After reading almost nothing positive about Bose, I've taken the LS 35 off my list, but would like to find something components similar in size / style with decent quality sound.
I found Anthony Gallos mentioned quite a few times in the forums, and their speaker look to fit the bill precisely (subject to a test listen obviously).
So now my questions:
Is there anything else that compares well to the Anthony Gallos speakers for form and function?
Can anyone suggest a combined receiver / DVD / CD that might work well with these that fits the criteria I set out above?
Am I seriously limiting performance at this price point by specifying a combined receiver / DVD?
Is there anyone (other than Bose) that make dual voltage equipment?
Sorry for the long first post. Thanks in advance for any help you can give me.
Wade
Wade
