buzzing sound with my xm radio! (1 Viewer)
andre-k
I hooked up my delphi xm radio to two different stereos in my home.. 1.an all onkyo system which buzzed terribly and did not go loud, but I replaced the mini to rca and it got much better, and 2. a bose system which had the same problem, but when I replaced the chord THE BUZZING DID NOT GO AWAY, even though it did on the onkyo (and dont say it's the bose, cause I know it sucks but not that bad!)
My question is if anyone else has had this problem and what did they did to fix it. Will buying monster cable mini to rca chords fix the problem. I also hate the fact that the music comes in so much lower then cd's and even normal radio. I have to crank both sytems up to hear the music.
Adam_Garris
I had the same problem when I got mine. Call Delphi and ask for a noise cancelling cable. It took care of my problem. Only thing is the sound is still too low... only problem with XM.
Brett DiMichele
Brett
I had the same problem untill I realized I didn't have the
Mini Plug pushed all the way into the base of the Home Kit.
If that doesn't solve the problem, or isn't the problem then
you have a Ground Loop issue and you need that free noise
cancelation cable (call Delphi)
blitz
