Jump to content
Connection for HDTV, Reciever, PS2, DVD
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   Todd_K
Todd_K
    Extra
  • 20 posts
Posted June 13 2003 - 05:13 AM
I just got a new HDTV and before I go spend some money on cables, I was wondering if someone could lend me some help on what my best connections should be. Specs: Mits 55411 Onkyo SR800 PS2 DVD player (not sure which one yet, but it will be coming soon) What cables do I need to hook up my Onkyo, do I run my DVD player (PS2) through my reciever, etc.. Please help!!!
#2 of 2 OFFLINE   Mr. Brian
Mr. Brian
  • 59 posts
Posted June 13 2003 - 09:39 AM
Your Mitsubishi should have 2 or 3 component inputs, so connect your PS2 and DVD player directly to the TV with component cables. That way you're assured the best quality. There's no need to run devices through the Onkyo unless you run out of itputs on the TV. Get an optical cable for your PS2, and depending on your DVD player, either an optical or coaxial digital cable. Those audio cables connect directly to the Onkyo. Brian
