Adam_Garris
- May 28, 2002
I just got my XM radio yesterday. It's a Delphi SKYFi and is hooked up to my Sony STR-DE575 via the RCA cables it came with. My only problem is the volume is low. I turned the line out level to MAX and that didn't help much. For reference, for DVDs or FM radio I keep the receiver at ~20 max. With XM I'm having to go up to ~30. This leads to another problem. Since it's being turned up so loud I'm getting a humming sound. Like when you have nothing on but turn the volume up. Has anyone else experienced these problems? If so, what are you doing?
btw, XM Radio is great so far other than those minor quarrels
