Josh Duve
Grip
- Jun 4, 2000
I am having problems with my Sony DVD player.
The player powers up just fine, but it doesn't like to play DVD or CD discs. If you put a disc in the player, it will try to spin the disc up a few times, and eventually NO DISC will come across the screen. Once in a while, if you eject and insert the disc a few times, it will eventually read the disc, but will start skipping during the movie.
I have tried cleaning the player with a CD clean disk, but still no luck.
Is there anything I can do, or is it dead?
Thanks guys.
Thanks guys.
