james e m
- Jun 3, 2001
So about once a year I come up with this great idea about buying a projector, so I wanted to do some research on a budget set up that would work for me. Right now I just have a 32" Sharp tv and I wanted a "cheap" way to watch movies on a big screen. Right now I have a hard budget of $2000 for a screen and a projector.
Originally I wanted to go with a DLP/LCD/LCOS RPTV but I would have to wait until I can afford one.
Could I get the same quality as an RPTV for a cheaper price? Or should I wait and buy and more expensive RPTV when I can afford it?
Since I have a 32" tv, I think I would need a screen that I can mount in front of the tv on a tripod (I have cathedral ceilings).
The projector would have to be removable and it would sit on a coffee table and the screen would be about 4-5 feet away from the projector.
I guess I'm looking to find a projector that would be more impressive than my 32" tv. I have no idea what screen size would be ideal for my room. I think the viewer would sit about 10' from the screen.
It will be in a large room with 2 windows and 2 openings (one to the kitchen and one to the foyer) so I think it will need to be bright.
I don't know much about projectors but, I think I want a 16 x 9 ratio and HDTV capabilities would be a plus!
If anybody could point me in the right direction or tell me some packages I should research that would be great.
James
James
