Jump to content
Need Someone w/ Tape Measure and Sony 4ES
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   Angelo.M
Angelo.M
    Producer
  • 4,007 posts
Posted May 12 2003 - 03:44 AM
This is ridiculous, but I need to know how far apart the feet are spaced on a 4ES. I have one at home, and I'm in my office at the moment, and need to know this measurement (putting one in here). Thanks in advance.
#2 of 6 OFFLINE   Dennis LM
Dennis LM
    Extra
  • 18 posts
Posted May 14 2003 - 06:27 AM
Angelo, I saw another forum post the distance as 30 cm. I will try to be more clear in which direction this is tonight.
Dennis LM.
#3 of 6 OFFLINE   Angelo.M
Angelo.M
    Producer
  • 4,007 posts
Posted May 14 2003 - 08:29 AM
Thanks, Dennis. I'm guessing it's 12 inches between the center of the feet front-to-back, but it's a guess.
#4 of 6 OFFLINE   Dennis LM
Dennis LM
    Extra
  • 18 posts
Posted May 15 2003 - 03:42 AM
Angelo, here are some more dimensions. STR-DA4ES base dimensions Foot diameter: 2” (1 15/16”) On-center distance of feet, side to side (width): 14” On-center distance of feet, front to back (depth): 12 ½” On-center inset of front feet from faceplate: 2 ½” On-center inset of rear feet from rear panel: 2 ¼” - 2 ½” On-center inset of feet from sides: 1 ½” Anything else, just ask.
Dennis LM.
#5 of 6 OFFLINE   Angelo.M
Angelo.M
    Producer
  • 4,007 posts
Posted May 15 2003 - 06:10 AM
great help; thanks Posted Image
#6 of 6 OFFLINE   Mark Hedges
Mark Hedges
  • 442 posts
Posted May 20 2003 - 12:15 AM
Dennis - Can you tell me how deep the unit is, NOT including the volume nob or any other protuberances? Thanks! Mark
