LarrySkelly
- Jan 9, 2001
I wasn't planning to buy a new pre-amp this soon, honest. I've been using a pretty decent receiver (Marantz SR8000) to drive three Martin-Logan's and a pair of B&W's in the rear. This week I took delivery of a Bryston 4BST to power the fronts, using the SR8000 as a pre-amp. Was planning to get a pre-amp in a year or so.
I'm very happy with the amp, however the amp has pointed out a problem in my receiver. The indicator LED on the Brystons glows red when they detect a problem with the input signal - typically excessive distortion or a short. The signal from my receiver starts out ok, but goes bad within a few minutes, possibly as the unit heats up, flickering on and off and degrading to the point that its continuous red.
Nothing is noticeable in the sound quality. But I've also noticed a slight popping sound in that channel as I increase the volume; at the point it pops the indicator turns red.
So I have undoubtably damaged my receiver driving such a hellish load, oddly enough the pre-amp section is affected, not the power amp. In any event I'm considering buying a pre-pro, a bit prematurely, but I don't want to operate in this mode for too long from fear of damaging the M-L's which would be a real disaster.
Thw wife and kids are quite conderned with this read light deal so I have a real opportunity here. :wink:
What pre-pro would you recommend? Requirements:
- 7.1 support
- excellent 2-channel sound quality (50% of the usage is music only)
- not sure about other features, just staring to do research
I'm not too concerned about a lot of bells and whistles for HT. I'd like a good solid HT processor with an excellent pre-amp section for 2-channel sound.
Max price $2K US, new or used. Preferably less, if I can still get good sound.
Recommendations?
Larry
- 7.1 support
Recommendations?
Larry
