Jump to content
Connecting computer to hdtv without rgb input?
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   Bill Va
Bill Va
  • 1 posts
Posted May 10 2003 - 11:25 AM
I'm about to take the plunge into Hdtv and am wondering if it is possible to use a hdtv as a monitor for my computer if said tv only has component inputs? Its tough deciding to get a new tv without HDCP DVI or without a RGB and any input would be appreciated. Posted Image
#2 of 2 OFFLINE   Derek Iverson
Derek Iverson
  • 191 posts
Posted May 10 2003 - 12:59 PM
Yes, it can be done. You'll need a transcoder such as the Key Digital KD-VTCA2 or the Audio Authority 9A60. Digital Connection also has a FAQ article to look at. It is very informative.
One of the problems that you'll probably face is overscan. Most RPTV's typically overscan by about 4-6%. This means that you most likely won't be able to see your Windows Taskbar fully. That can make navigation a bit difficult. ISF calibrationists can usually fix overscan pretty well, but you may or may not be willing to have something like that done (costs $$$).
Another option would be to use a program like PowerStrip to fix the overscan. This will probably not be as easy as an ISF calibration though.
My Home Theater
My DVD Collection
“JBL S-Series + SVS = ” - Phil Iturralde
The Portland, OR & Vancouver, WA HT Meet Thread
