Ryan Frederick
- Apr 14, 2003
I had a Hitachi 51UWX20B delivered about a month ago and just love it. I am using it with a Sony NS715P running through component in on the TV, progressive on. I calibrated with S&V Home Theater Tune-Up and have the settings as follows:
Contrast 33
Brightness 51
Color 46
Sharpness 40
Tint a very small bit right of center
Color Temp High
All advanced settings off
I have also entered the service menu and changed the following settings to correct red push
RY-PH-F 02
R/B-GAF 03
GY-PH-F 01
G/B-GAF 04
Colors look vibrant and DVD's are very sharp. It's a great set except for one problem. The problem is in dark scenes. The shadows seem to have no detail. Any area in the scene that is supposed to be shadowed a bit looks as black as the areas that are supposed to be pitch black. Does that make sense? I'm not sure I am explaining it correctly. Any advice would be greatly appreciated. Thank you! -Ryan
EDIT: Is there any way to edit the title of my post? Yes, it's been a long Monday and I spelled shadow incorrectly.
Contrast 33
Brightness 51
Color 46
Sharpness 40
Color Temp High
RY-PH-F 02
R/B-GAF 03
GY-PH-F 01
G/B-GAF 04
