Need 3802 Help! (1 Viewer)
Brett Nix
I have a Denon 3802 set up for 5.1 sound in the den. I finally got my N26's installed on the porch as the "Multi-Zone" speakers. Is there any way to turn them OFF? From reading the Denon manual, it appears you can only turn the volume all the way down, but not cut the power completely. Any ideas?
CurtisC
Are you sure you can't turn z2(MULTI) off or on?I have the 3803 and it can be.Check the z2(MULTI) buttons on the front of avr.
Tommy_N
I have the 3802, but do not have a second set of speaker set. I just have the second zone set to an input that I'm not using.
Wouldn't that work for you?
Tom
Brett Nix
Probably. That's what I've been doing, I just wanted something a little more positive - i.e. off being OFF. Thanks anyway.
acinstallation111
