Don
- Jun 30, 1997
Properly/safely set it right now i have my receiver set at 3 + dbs is this safe or good to do plus how high should the volume on the tv should it be before you turn the speakers off. also what db level on the receivers knob do you have it set at before you calibrate it. can anyone please answer or help. Don,
