Jump to content
Anyone power their DIY Subs with old receivers?
  • Please log in to reply
11 replies to this topic
#1 of 12 Andrew S
Andrew S
    Advanced Member
  • PipPipPip
  • 215 posts
Posted April 20 2003 - 02:04 PM
I always read of people power their subs with plate amps, etc,. but I can't afford to shell out the cost for a plate amp, so I just use an old Pioneer receiver.
I was wondering if anyone else was in the similar situation?
Andrew
Wish I had more money
#2 of 12 Michael Hartwig
Michael Hartwig
    Advanced Member
  • PipPipPip
  • 56 posts
Posted April 20 2003 - 03:02 PM
I originally powered my Tempest with my JVC receiver that was rated at 120 RMS 8 ohms/channel. I used both L and R to power the DVC of the Tempest. I found by using the DVC capabilities of the Tempest with my JVC I was getting a flatter response down to 20Hz than I do now with my Adire AV250 running 4 ohms with the Tempest DVC shorted to 4ohms. But the AV 250 does give me more slam. So I gain in one area and loose in another.
That's my experience.
#3 of 12 Cam S
Cam S
    Advanced Member
  • PipPipPip
  • 1,524 posts
I've heard of alot of people powering subs with old receivers. I didn't have an old one that wasn't in use already so I had no choice but to go with a plate amp, and I'm kinda glad I did as it's more of a complete package.
MOOOOOO
#4 of 12 Joel X
Joel X
    Advanced Member
  • PipPipPip
  • 50 posts
Posted April 20 2003 - 03:33 PM
I power my sub and bass shakers with old receivers and think it is a great idea. No problems here...
#5 of 12 Jonathan_D
Jonathan_D
    Advanced Member
  • PipPipPip
  • 142 posts
Posted April 20 2003 - 11:24 PM
I power my Tempest with an old H/K integrated amp. While its not a lot of power, it *can* shake shelves on the walls.
I agree, I think its a great idea if you've got spare amplification hanging around.
My Home Theater (in progress):
JVC AV-32F703 32" TV
JVC XV-SA602SL DVD Player
Harman Kardon AVR 520 Receiver
AR-DIY Loudspeakers Front MainBIC DV62CLRs Ed Frias Modified Center ChannelBIC VI-38 In Wall (ceiling) SurroundsAdire Tempest 122L sealed passive subwoofer powered by a H/K PM650 Integrated AMP....
#6 of 12 Jeremy Stockwell
Jeremy Stockwell
    Advanced Member
  • PipPipPip
  • 608 posts
Posted April 21 2003 - 02:30 AM
I power my DIY Tempest Sonosub with an old Kenwood Pro-Logic receiver from college (100W x 2). Works fine. I would recommend using a driver with DVC so that you can use both the left and right channels to get max from the amp.
The only potential problem is HEADROOM. I don't often play DVD's anywhere near reference, but when experimenting with higher levels, I can tell that the sub amp can't keep up as it approaches reference.
If you've got the hardware lying around, I would definitely try it, at least.
JKS
You brought two too many.
#7 of 12 JeffTodd
JeffTodd
    Advanced Member
  • PipPipPip
  • 200 posts
Posted April 21 2003 - 02:43 AM
I power my SVS based sonosub with my old Aiwa prologic receiver (supposedly 100w per)......it works well, but I am hoping to get a plate amp to push it better.
#8 of 12 Stuart A.
Stuart A.
    Newbie
  • Pip
  • 3 posts
Posted April 21 2003 - 08:53 AM
What is everyone using for a crossover?
#9 of 12 Andrew S
Andrew S
    Advanced Member
  • PipPipPip
  • 215 posts
Posted April 21 2003 - 09:51 AM
Stuart, I don't know about everyone else, but I basically just use the built in crossovers in my receiver and then send it to my older receiver. On my receiver I just turn the treble all the way down the bass at normal. I don't know if this is the correct way to do it, but it suits my tastes well.
#10 of 12 Ben Ven
Ben Ven
    Advanced Member
  • PipPipPip
  • 61 posts
Posted April 21 2003 - 11:39 AM
I power my sub with an old Pioneer receiver, VSX-9500S. It is rated at 125W per channel. You can run 2 subs if you have an A/B set up on your receiver. I wonder if a plate amp would sound better with my set up?? Anyway, I am too cheap to spend the money on a plate amp Posted Image . The Pioneer seems to have plenty of oomph.
Andrew, at least on my receiver, the tone controls are bypassed when I input the sub signal from my Yamaha receiver to the Pioneer receiver pre amp input. No need to turn down the treble control. FYI.
#11 of 12 Owen Bartley
Owen Bartley
    Advanced Member
  • PipPipPip
  • 486 posts
Posted April 22 2003 - 03:43 AM
I was doing this last year with an old 10" car sub. It was powered with everything from an old mini-system (!) to a Kenwood 1970's receiver at about 80 - 100 wpc.
For a crossover, I just picked up one of those big $10 coils (capacitor, right?) on a little PCB from an electronics store. It was supposed to block out about 100Hz and up. I built a little box for it, and ran it between the amp and sub. For a ghetto solution, it didn't work too badly.
#12 of 12 Jonathan_D
Jonathan_D
    Advanced Member
  • PipPipPip
  • 142 posts
Posted April 22 2003 - 05:17 AM
Like others, I just run it straight off the LFE/Sub out from my H/K receiver. The H/K bass management is pretty good (though not as good as the newer models). I have it set at 60hz (my mains will go down to 50 or 55 hz) and includes the bass from the L+R and rears as well as the LFE. The amp I use has a tone bypass switch that I use as well as a "high cut" filter.
