Jump to content
Sign up for a free account!
DVD Audio Out Question
6 replies to this topic
#1 of 7 FrankieD
FrankieD
  • 9 posts
Posted April 20 2003 - 10:59 AM
I'm re-wiring my system because I can now take advantage of the digital output of the unit . My question is: do I connect BOTH analog and DIGITAL audio outs into my receiver, (Toshiba DVD player, Yamaha RX-V1300), or just the DIGITAL audio out? Thanks in advance.
Frank
#2 of 7 Michael_T
Michael_T
  • 461 posts
Posted April 20 2003 - 12:06 PM
You can connect both the analog and digital out - and I would probably say this is the best thing to do.
If you are talking about DVD-Audio (as opposed to DVD-video DTS or DD), then YOU HAVE to hook up the analog outs to take advantage of the higher resolution DVD-Audio provides.
#3 of 7 MannyE
MannyE
  • 233 posts
Posted April 20 2003 - 04:13 PM
Use both. You will find that sometimes you either need or prefer the analog outs.
Ni!!
#4 of 7 Grant B
Grant B
    Producer
  • 3,213 posts
Posted April 20 2003 - 06:01 PM
1 other option
Hook up the analogs straight to the TV and the digitsl to the Xcver
Some times this arangement works out the best
"Whatever it is, I'm against it!" G. Marx
Sony TAE/TAP/TAN(2)9000ES;DVP-CX860 DVP-CX777ES
Sony CDP-CX270 CDP-CX355 CDP-CX270 CDP-CX355
Sony S-TS 700ES XPR32450Pioneer Elite CLD 79 KEFs (5) Q75s & 20B Subwoofer
#5 of 7 John-Miles
John-Miles
  • 1,201 posts
Posted April 21 2003 - 02:32 AM
Grant the Analog outs need to be run into the receiver, there are 6 of them so you cant even connect them all to the tv.
Frankie, if you really wan tto cut down on cables you can elave out the digital cable and use the players decoders, but personally i prefer the decoding in my RX-V1300 to any players decoding.
Cheers
#6 of 7 Mike Milillo
Mike Milillo
  • 142 posts
Posted April 21 2003 - 02:49 AM
I assume by analog wires from dvd player you are refering to the single rca connector cables for each speaker that is on the back of dvd players and receivers. Just a question, why would you need to use both the analogs and the digital? Just curious, never heard this before, thanks?
#7 of 7 John-Miles
John-Miles
  • 1,201 posts
Posted April 21 2003 - 07:54 AM
If his Toshiba dvd player is also a DVD-Audio player there will be 6 analog RCA outputs for DVD-A playback.
you would also use the digital connection to allow the receiver to do the decoding for DD and DTS, only the player can decode the DVD-Audio
Cheers
