Jump to content
Help Please: looking for 50-53" HDTV for $2000
  • Please log in to reply
17 replies to this topic
#1 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 20 2003 - 04:16 AM
Hi..I have an entertainment center with a 53in wide opening to place a large screen tv... It apppears that the biggest widescreen tv I can place will be in the 50-53 in screen.... what can you remember in the $2000 range... I have looked at Sony 51in HDTV(SONY KP51WS500) ..but I have seen large number of flicker or color issue in reviews at CC..$1999 I liked the pic on the RCA Scenium 52" RCA D52W135D ..I hate the idea of built in DVD player(and paying for it) and I have seen people have had issues with it $1899 Hitachi 51'' Widescreen Ultravision HDTV Monitor Brand/Model: HIT 51UWX20B..$1999.99...older version?? vs Hitachi below Hitachi 51" Widescreen Ultravision HDTV Monitor Brand/Model: HIT 51SWX20B ..looks real nice it bit more than I want to spend.. $2500 I am not sure what features to look for..the more I read the more confused I get...
#2 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 20 2003 - 09:24 AM
anybody
#3 of 18 OFFLINE   JoeHard
JoeHard
  • 136 posts
Posted April 20 2003 - 11:22 AM
I just bought a Pioneer SD-533HD5 this past week for 1995.00 at a local A/V store and am very pleased so far. I consdered the 51 inch Sony and could have bought it for 1495.00 at hh gregg but I liked the Pioneer better and felt it to be worth the extra cash. Good luck
#4 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 20 2003 - 11:27 AM
thanks..what did you feel made the difference ...picture quality...features...
#5 of 18 OFFLINE   Greg_L_C
Greg_L_C
  • 126 posts
Posted April 20 2003 - 01:45 PM
I recently bought the kp46ws500. With a little AVIA tweaking the picture is excellent. I saw a service bulletin on Sonys website about the flicker problem with the 51. They said it is isolated to a small number of projectors and offer replacement projectors if it occurs. Greg
#6 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 20 2003 - 02:15 PM
Thanks Hmm..nice to know the Sony only has 4 lens setup whereas the others use 5 lens..is this an important difference
#7 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 20 2003 - 02:41 PM
The Pioneer SD-533HD5 has some very nice reviews..I would prefer to find it in a retail store if possible...anyone know a place in the Tampa,FL area
#8 of 18 OFFLINE   Greg_L_C
Greg_L_C
  • 126 posts
Posted April 20 2003 - 03:22 PM
Their are others here that can give you a more accurate answer, but I believe the number of lens elements has more to do with adjusting the focal length and increasing the "sweet spot" or raster of the lens. Other things Like diameter are important to. All models your looking at would have high quality lenses. I bought the Sony for the price, DVI, dual turners, picture modes seemed better than the Mits or Hitachi's I looked at. Greg
#9 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 20 2003 - 11:04 PM
thanks...Greg LC
#10 of 18 OFFLINE   sean_pecor
sean_pecor
  • 137 posts
Posted April 21 2003 - 03:09 AM
Important! Don't let your 53" horizontal width limit you to 51" or smaller sets. Keep in mind that 16:9 widescreen TV dimensions are diagonal size, which works out to a smaller horizontal width!
Examples:
The 57" Toshiba 57HDX82 is exactly 52.2 inches wide and you can grab one for under $2,000.
The 55" Mitsubishi 55311 is around $2,000 and the enclosure is 50.5" wide.
And so on...
BTW, I'm not necessarily a proponent for larger screens. I recently purchased a Sony KP46WT500 and love it!
Sean.
President, Lead Developer
Digital Spinner, Inc.
http://www.digitalspinner.com
#11 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 21 2003 - 03:38 AM
Thanks for the good advice No I am not limiting myself based on pic size..but width of the TV cabinet to insure it will fit in the enclosure..really do not want to get it home and find it is a 1/2 in to wide...opening is about 53in..maybe touch less..so I am staying with sets in 50in width..if I can find one slightly bigger I would
#12 of 18 OFFLINE   baja
baja
  • 29 posts
Posted April 21 2003 - 09:21 AM
NealH I am in Tampa also. Hey neighbor!...lol I am currently having a house built with an entertainment center being built. My finished opening will be 54" wide, not far from yours. I am looking at the Pioneer Pro 530 and Mit Platinium 55511. I know these units are more $ but either of these units should fit in your opening.
#13 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 21 2003 - 10:55 AM
Small world..Baja How much more are these TVs...Pioneer Pro 530 and Mit Platinium 55511 the Pioneer SD-533HD5 has nice reveiws seems Pioneer makes so very nice HDTV
#14 of 18 OFFLINE   Josh_SR
Josh_SR
  • 105 posts
Posted April 21 2003 - 11:25 AM
sup peeps... i have the RCA Scenium 52" RCA D52W135D and its great so fare .... picture is very nice and the dvd player is a nice plus to....... my only problem with the dvd player is that all the reds in movies look blocky..... but i read most dvd players do this.
#15 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 21 2003 - 01:33 PM
At CC the picture on the RCA looked nicer than the Sony...did not compare it to the Hitachi...and have not seen a Pioneer yet....
#16 of 18 OFFLINE   John Geelan
John Geelan
  • 1,092 posts
Posted April 22 2003 - 11:46 AM
"Hitachi 51" Widescreen Ultravision HDTV Monitor Brand/Model: HIT 51SWX20B ..looks real nice it bit more than I want to spend.. $2500" That Hitachi gets rave reviews. Very comparable to the Pioneer for less the price.
JohnG
(Proud Home Theater Forum Donor)
Sony KDS-R50XBR1 (SXRD)Denon AVR3806/ DVD3910Toshiba HD-DVD XA2/ Sony PS3Onix Rockets RS550MKIIsSVS 25-31CS subwoofer
#17 of 18 OFFLINE   NealH
NealH
    Extra
  • 24 posts
Posted April 22 2003 - 11:49 AM
John G do you own a Hitachi??
#18 of 18 OFFLINE   JoeHard
JoeHard
  • 136 posts
Posted April 22 2003 - 02:12 PM
I bought the Pioneer because I thought it had the best picture for the price.Picture is sharp and no red or green push.The stretch modes are also very good.No DVI input.
