Myo K
- Mar 27, 2003
which would be more fitting for me?
how accurate are dennon receiver specs compared to hk? my understanding is that hk actually exceeds the listed wattage specs by a few watts-while dennon's listed watts are a bit iffy, not really outputting what is listed.
the hk lists at 55 watts per channel
and the dennon lists 80 watts per channel.
how accurate would you consider the rating for the dennon? as an entry level denon i dont know if the ratings should be taken seriously, same goes with hk, but i think id find hk closer to the real output that is listed for the receiver.
dts es and dd ex does not matter to me, im perfectly fine with a 5.1 set up at the moment, so what i want to know is between the two models, which receiver provides the most reliable performance and quality?
the 225 and 1803 are both listed at 500 dollars, but the denon offers 6.1 decoding as opposed to hk's 5.1 decoding and 25 watts more power,
since im new to the audio world, id like to know how the pricing of these companies work..
am i just paying extra money for nothing with the hk? or is it the other way around in which im sacrificing performance, and false power specs, with the dennon?
which receiver would be the best for me? if the denon will at least output a minimum of 55 watts @ 8ohms through 6 channels continuously with head room to spare, then ill get the denon, its hard to believe that the denon can out 80 watts through 6 channels sontinuously for a 500 dollar entry level receiver.
ill be using it a lot for music, so i need a clean sound, itll will be used for movies too, but mainly for music.
is the denon 1803 receiver high current like the harmon kardons also?
another entry level model im looking into is the pioneer 912k, which seems to offer an abundance of feature for 300 dollars? listed at 110 watts through 6 channels? now i dont know if this reciever is just spewing out marketing mumbo jumbo, because i cant possibly conceive why anyone would pick an hk or denon if theres a reciever like 912k in the sub 500 dollar price range.
i assume, the quality of sound and performance was greatly sacrificed to fit all that into a 300 dollar reciever? i keep reading about fake specs by companies low end receivers, so i would assume that the hk would produce better power output over the pioneer? they may say its 110 watts but most likely itd be 40 watts x 6? am i correct in my assumptions?
ive been force feeding my brain with all this audio research to prevent me from falling victim to marketing hype or getting ripped off :frowning:
forgive me if my questions are sound silly, but im an audio noob, i hope you guys can bare with me, as i expand my knowledge about audio
