Brian Mansure
- Mar 15, 2000
Hey all,
it's been a long while since posting on this part of the forum but I'm sure I have the right place for help.
The main tv cable supply used to run directly from the utility pole into my attic where it was split off for 2 televisions.(fairly common)
Since then, I've had a cable modem installed and now the main drop is split once outside of my house and then again in the attic.
The outside splitter has one output going directly through the wall to my cable modem and the other output is going up to my attic where it is split to the same 2 televisions as before.
My questions are:
Would it be a better cable run if I eleminate the outside splitter (which is an uncovered 2-way TVC brand) and once again have the main drop going directly into the attic to be distributed 3-ways or more from there?
I'm assuming the less splitters there are, the less potential for signal loss/noise especially if the splitter would be inside not subjected to outside weather and such.
Also, if I would need to re-run the cable, should I continue to use the Comcast provided splitters or should I spend some money on 2ghz splitters?
I appreciate any assistance with this.
Brian
My questions are:
Brian
