Jump to content
Sign up for a free account!
DirecTV using a Dish dish?
3 replies to this topic
#1 of 4 Al Pearson
Al Pearson
  • 6 posts
Posted April 14 2003 - 09:30 AM
I just bought a new place and it is wired up for sattelite, Dish Network. I want to use a DirecTV setup, I know I need to point it at 111 deg or so but do I need to change the dish (18') and more importantly the LNB's?
#2 of 4 Steve Schaffer
Steve Schaffer
    Producer
  • 3,759 posts
Posted April 14 2003 - 12:33 PM
LNBs for sure, probably the dish too.
These are pretty much available for free for most new DirecTV customers. Tell them you want the Para Todos spanish package and they'll give you an oval dish that will require only a 3rd LNB kit ($8) to get all the HD channels when you choose to upgrade.
Steve S.
I prefer not to push the subwoofers until they're properly run in.
#3 of 4 Al Pearson
Al Pearson
  • 6 posts
Posted April 14 2003 - 02:10 PM
I'm a current customer...the new place is a cottage.
#4 of 4 Robert_J
Robert_J
    Lead Actor
  • 8,051 posts
  • Real Name:Robert
  • LocationMississippi
Posted April 14 2003 - 11:53 PM
I hope you meant 18". If it is a standard 18" Dish300 then it is EXACTLY like DirecTV 18" dishes.
It's currently pointed at 119. Swing it back to the left and up a little to point at 101. The DirecTV receiver will give you coordinates.
If you get up there and find out it is a 20" Dish500, it may still work. Older Dish500s came with two standard LNBs for pointing at 110 and 119. Remove any Dish switches and connect 1 LNB to your DirecTV system. Set the skew to zero and aim. Newer Dish500s have a Twin or Quad LNB. That's two LNBs and the Dish switches built into a single housing. It will NOT work with DirecTV.
-Robert
Forum Nav Content I Follow
