Which DVD player audio-output is best? (1 Viewer)
BrianGC
Hello,
I'm curious which audio output on my DVD player (PAN CP72) would be the best to use? The player has optical digital out and multi-channel audio out (FL, FR, Surr. L, Surr. R, Center, Sub).
I would have to get a new receiver to use either one of those, but just wondering which would be best if I do?
BrianGC
Tim Hoover
Brian, the multi-channel out is mainly used for DVD-Audio. If you're not interested in that, then the optical out would probably be a better bet, due to the likelihood of your receiver having better DD/DTS decoding than the '72.
H-508
