Michael De Costa
- May 8, 2001
I went into a local WIZ store that was going out of business, and made an impulse buy. They had one Samsung T151 HDTV decoders on sale for $269. With 75% of the store already empty, and only one of these left (new in the box), I decided to but it. When I got home and was all excited about having HDTV finally for my Toshiba57HX81, became very surprised at what I learned: No feed for DIRECTV! I knew when I purchased it, that it didn't have a DIRECTV built in capability, but thought it would just require it to be hooked up to my Sony SAT-T60 DIRECTV box. No such luck. After reading up on the SIR-T151, I found that it was just for local over the air broadcasts. Man was I pissed. All sales were final: No returns!
Is anyone using this set? Is it worth keeping? I can't believe a normal antenna hooked up to this is going to get me a great High Def. Picture. I don't want to go through the hassle of putting up an antenna if it's not going to look that great. If that's the case to E-bay it goes! If you are using it, do you rec. any certain antenna for it? Esp. if you currently have DIRECTV.
Thanks for any advice.......
