Jump to content
NEW Subwoofer help!!!
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   ChristopherW
  • 36 posts
Posted April 10 2003 - 04:00 PM
I just got a new subwoofer, but I need some help setting it up. It's a Stryke AV12 with 2 15" PRs and an AMP350 When I connect from my sub out on my receiver to the line in on the sub all I get is a hum throughout my system. It stays the same regardless of the volume or the source. Adjusting the subwoofer level on my receiver makes no difference. It seems to me like my sub is not receiving any information. also I tried connceting it via the high level inputs with the same result. HUMMMMMMM. Do you guys have any ideas? Thanks, Chris
#2 of 6 OFFLINE   Rick_Brown
  • 449 posts
Posted April 11 2003 - 12:05 AM
Make sure that you have told your receiver that you have a sub by selecting it in the setup menu.
#3 of 6 OFFLINE   Kyle Richardson
Kyle Richardson
  • 1,076 posts
Posted April 11 2003 - 01:34 AM
Sounds like a possible ground loop hum. Try searching the forum for "ground loop hum" and you will get many hits with all of the possible remedies. Good luck!
Kyle Richardson
Acoustic Visions
AOL Instant Messenger Name: kyler70
MSN IM: acousticvisions@hotmail.com
#4 of 6 OFFLINE   Brian Bunge
Brian Bunge
  • 3,719 posts
Posted April 11 2003 - 04:27 AM
I built the sub for Chris and it worked fine here in the shop. I also suggested he make sure that his pre/pro was setup to send the sub a signal. Kyles suggestion is a good one too. A cheater plug might be in order.
Brian Bunge
RAD Home Theater
#5 of 6 OFFLINE   ChristopherW
  • 36 posts
Posted April 11 2003 - 11:42 AM
Well the hum is gone! I found out that it was caused by the CATV connection! Now I just gotta fool around to get some signal flowing to the sub. Thanks for the help you guys!
#6 of 6 OFFLINE   Greg_R
  • 1,998 posts
  • Real Name:Greg
  • LocationPortland, OR
Posted April 11 2003 - 11:48 AM
[quote] A cheater plug might be in order. [quote]Not always an electrically safe recommendation (it depends on the sub's amp). Call the manufacturer to see if bypassing the ground is safe. Chris, here's my post in the HTF Faq describing some potential ground loop solutions.
