Jump to content
setting up or calibrating my receiver how do i.
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   Don
Don
  • 376 posts
Posted April 10 2003 - 12:25 AM
do this. i have a Denon AVR-3200 receiver and would like to know how to properly calibrate it. do i keep the Low Frequency Outlet set to - 0 or do i change it. also on my setup menu i have a screen that has controls on it will it be safer to move them down or up. also i will be getting a SPL meter soon from the rat-shack. Don,
#2 of 2 OFFLINE   ChadLB
ChadLB
  • 1,523 posts
Posted April 10 2003 - 02:46 AM
You will need either the Sound&Vision disc or Avia to run thru test tones on your speakers. You can just use the onboard ones but I feel that the discs do a better job.
