Jump to content
Right Angle Component RCA Adaptor
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   Chris Hovanic
Chris Hovanic
  • 545 posts
Posted April 09 2003 - 04:22 AM
I just bought some new cables to move all my gear to a closet in the rear of my Theater/Family room. I moved my Toshibia SD3815 DVD changer into the closet and because its so deep I cant place it as close as I would like to the back of the closet.
Does anyone make a 75ohm Right Angle adaptor for component video cables?
I purchased my Canare component cable from BDCable and would like to maintain some quality.
Thanks for any info Posted Image
Chris Hovanic
"Go away or I'll replace you with a very small shell script!" :wink:
My DVD Collection
My Home Theater Pictures
#2 of 3 OFFLINE   Chu Gai
Chu Gai
    Lead Actor
  • 7,270 posts
Posted April 09 2003 - 08:31 AM
Canare, I believe, makes a right-angle RCA plug but not sure if it's an adapter. Right angle adapters will be found marketed by... Monster ~ $13/pair Acoustic Research HT417 about $10/pair Radio Shack...dunno about price. I'm sure that in your yellow pages there'll be some electronic places that'll also carry them. You could certainly order them online but s/h is likely to be a substantial portion of your order. While I appreciate your desire to maintain as close to a 75 ohm path as possible, it's actually a non-issue with the RCA plugs as their contribution to the signal path is maybe an inch total. This is far less that 1/4 of the wavelengths your cable will be passing.
#3 of 3 OFFLINE   Chris Hovanic
Chris Hovanic
  • 545 posts
Posted April 09 2003 - 08:36 AM
Thanks Chu Gai I will have to pick some up next time Im out to frys
Chris Hovanic
My DVD Collection
