Jump to content
Help completing me system
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   Chris Elm
Chris Elm
  • 120 posts
Posted April 08 2003 - 04:10 PM
Ok right now I've got RF3II mains from Klipsch, got an RC3II center on the way, and two ss-1 surrounds. What should I do to fill out my system to 6, possibly 7 channels? Should I be looking at only Klipsch reference for better timbre (even though the surrounds are synergy series, got a great deal on them) or a second center channel or what? The way the room is laid out, it is a rectangle and then at the end it corners into a pie shape. __________________________ sub....................s.................- _ ..............................................- _ w................................................. .- _door a................................................. .....- _ l.................................c............... ...........l l................................................. ............l ................._____s______________________l (open space) the tv sits along the side labeled wall 'c' is the couch s is the surrounds sub sits in the corner (SVS 2231 PCi) This will be the new room, so nothing is mounted yet or anything. the basement is still being finished. I have decided on a Pioneer ELITE 45tx for the powerhouse. Any suggestions speaker wise will be wonderful. Thanks. EDIT: please ignore all the dots. they are just there to make it look right.
#2 of 4 OFFLINE   Chris Elm
Chris Elm
  • 120 posts
Posted April 09 2003 - 05:04 AM
Anyone??? Would I be okay going for some cheaper speakers in the rear? Or maybe I should just get another RC3II center for the rear the way the room is layed out?
#3 of 4 OFFLINE   Frank Carter
Frank Carter
  • 1,188 posts
Posted April 09 2003 - 05:31 AM
Hey Chris, I'd look into getting RS-3's for the side surrounds and moving the SS-1's to rear surrounds. The SS-1's are good speakers. Even though they are Klipsch, the synergy sound quite different from the Reference.
#4 of 4 OFFLINE   Chris Elm
Chris Elm
  • 120 posts
Posted April 09 2003 - 02:55 PM
Frank I was thinking about that, but after I get my receiver, I will have spent just under 2500 dollars on this new system, and I am only 17! I think I may be running thin with the PAF (parent acceptance factor)... Thanks for the reply. Any other input would be greatly appreciated.
