Denon 3802 owners, I need Help! (1 Viewer)
RobP
I was recently testing a 3802 at home to see if it could fit the shoes as I need a new processor. One thing I didn't like about it though is when using the video switching I couldn't listen to the radio and watch TV at the same time. It was only one or the other. I like to often watch games and listen to the radio instead of the TV Commentators. According to my local retailer this can be fixed but for the life of me I couldn't figure out how to do it. Does anyone know if this is possible to adjust?
JeremySt
Jeremy
Select the source you want to listen to. Then press the VIDEO SELECT button on the front panel repeatedly, cycling throung all the video inputs. Stop on the one you want to watch. To go back to normal, just select a different source with the yellow buttons on the remote.
acinstallation199
