DanSt
- Dec 19, 2000
Hey all!
I just installed my first projector and have come up against a wall. My pull-down screen hangs down right in front of my components and I can't use my remotes through it. I tried using Radio Shack's new RF/IR remote with command station but it only comes with 1 IR extender module and doesn't control all of my components because they are located far apart. Plus, it had trouble controlling my Pioneer Receiver for some reason.
So basically what I need is a remote (or even an IR extender) that will let me control multiple components from behind a screen. Preferrably one that has small IR modules so I can place them near the IR sensor on the equipment.
Any help on this would be GREATLY appreciated!!
