Jump to content
Antenna signal booster
1 reply to this topic
#1 of 2 OFFLINE   JerryJ
JerryJ
  • 1 posts
Posted April 01 2003 - 08:31 AM
Hi Group,
I am new to the group and this is my first post. I have a large directional antenna laying flat on my patio roof to keep the neighbors from complaining. I had it connected to a 27" tv and all was well until I purchased a toshiba 50hdx82. There is a large two story house between the antenna and the transmitting towers about 25 miles away all in the same place. I was wondering if a signal booster would give it more performance to the new set in a positive way. I have a signal booster in my motorhome connected to a winegard antenna and it really gets that tv to stand at attention! Do you think it would have the same effect on my home system.
Thanks Jerry
#2 of 2 OFFLINE   Grant B
Grant B
    Producer
  • 3,213 posts
Posted April 04 2003 - 02:30 PM
Antennas are funny things. An old engineer once told me that antenna design is more a 'black art' then a science.
I would try it but make sure you can take it back.
So it was fine when you had the 27 hooked up but now the new tv cant pick up the same stations?
Are you sure you have a good connection to the TV?
Do you have a rotor?
Sometimes a few degrees can make a huge difference and when it is highly direction even more so.
One thing that they do is 'reject' signals off the sides and back.
Good Luck
Grant
"Whatever it is, I'm against it!" G. Marx
Sony TAE/TAP/TAN(2)9000ES;DVP-CX860 DVP-CX777ES
Sony CDP-CX270 CDP-CX355 CDP-CX270 CDP-CX355
Sony S-TS 700ES XPR32450Pioneer Elite CLD 79 KEFs (5) Q75s & 20B Subwoofer
