Jump to content
recommendation for a very good indoor, urban FM antenna?
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   VincentY
VincentY
  • 80 posts
Posted March 31 2003 - 12:02 AM
i'm getting my B&K 507 today and, being in nyc, need a very good FM antenna for indoor urban use. should i just get one of those Terk things or are there some that are much better? thanks!
#2 of 6 OFFLINE   LewB
LewB
  • 1,282 posts
Posted March 31 2003 - 12:23 AM
Since you are in the city, why not just try the wire antenna that comes with the unit? I remember getting great FM reception in the Bronx with just the wire antenna. If you don't like the results you can then investigate other options. I have a powered Radio Shack antenna that seems to do the job (I don't listen to FM much on my receiver). Do you have cable TV, perhaps they provide FM stations ? Is an outdoor antenna a possibility ?
#3 of 6 OFFLINE   Scott Kriefall
Scott Kriefall
  • 332 posts
  • Real Name:Scott
  • LocationSLC, Utah
Posted March 31 2003 - 01:14 PM
Dipole antenna, $3.99. It's highly unlikely that any of the Terk or similar indoor antennas will work any better -- and most will probably be quite a bit worse.
#4 of 6 OFFLINE   VincentY
VincentY
  • 80 posts
Posted March 31 2003 - 04:12 PM
Scott, Why wouldn't the Fanfare or Dynalab 1/2 wave models work a lot better?
#5 of 6 OFFLINE   Scott Kriefall
Scott Kriefall
  • 332 posts
  • Real Name:Scott
  • LocationSLC, Utah
Posted April 01 2003 - 05:00 AM
I was referring to the Terk, Parsec, and other similar little indoor antennas -- whether amplified or un-amplified. The Fanfare and Dynalab are well thought of, however, and may pull in weak signals better than a simple dipole.
#6 of 6 OFFLINE   shankar
shankar
  • 91 posts
Posted April 01 2003 - 07:29 AM
The silver sensor from Sears or circuit city. $39.
Sincerely,
Shankar
