MikeJV
- Mar 29, 2003
Hi,
I am interested in purchasing a Pioneer 811s from the US, however I live in Australia.
In Australia, we use 230 volts and I was wondering if the 811s can be used in this situation. e.g. does it have a switching power supply, or does it have a switch on the back where you can set which voltage you wish to use.
If it cannot be used for anything other than 120 volts, is there another a/v receiver option with similar performance and in the same price bracket that would be useable here in Australia?
Michael
Michael
