-Not Logged In-
Jump to content
DVD audio connection for SR7200 or sr 7300
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   Hisham_k
  • 14 posts
Posted March 28 2003 - 07:36 PM
Hi guys : for the owners of marantz SR 7200 or Sr 7300 , by connecting a DVD audio player thru the analog inputs, to what input do you set the receiver to : will it be multichannel or do you keep it in auto mode ? Using multichannel input will require going to the menu of the receiver every time and setting the multichannel to on. Then for watching movies it should be set to off. A digital connection is used as well from the dvd player to the receiver. By the way I am using a CP-72 as a DVD-A and DVD-V. Your help is highly appreciated.
#2 of 2 OFFLINE   ChrisAG
  • 503 posts
Posted March 29 2003 - 03:09 AM
Posted Image Posted Image Posted Image
Sorry, but you're wrong on almost every count!
"Auto" mode is not for sensing an input, but rather for a surround processor mode (e.g. Dolby Digital or Dolby Pro-Logic, etc.)
For connecting DVD-A or SACD, you would use the 6.1-ch input (7.1 on the 7300), [even though DVD-A and SACD are only 5.1, Marantz has the extra input channel].
You do not need to go into the on screen display in order to activate or de-activate the input, there is a switch on the front of the receiver and a button on the remote for this.
