Jump to content
Sign up for a free account!
Signing up for an account is fast and free. As a member you can join in the conversation, enter contests and you won't get the popup ads that guests get. Click here to create your free account.
NEED HELP w/ Viewing Distance
7 replies to this topic
#1 of 8 Larry Pinell
Larry Pinell
  • 8 posts
Posted March 22 2003 - 04:03 AM
I'm new at this. Sorry if I submitted the wrong post before.
I AM PLANNING TO BUY ASAP A 27" SONY WEGA AND I WILL BE SITTING 8.5 FT FROM THE SCREEN. DO YOU THINK THIS IS A SUFFICIENT SCREEN SIZE?
IT WOULD BE TOUGH TO AFFORD A 32"
PLEASE RESPOND TO
SPINKAT@SYMPATICO.CA
THANK YOU!
#2 of 8 Rod_Gwinn
Rod_Gwinn
  • 8 posts
Posted March 22 2003 - 08:12 AM
Try doing a search on Viewing Distance
You should find several posts that answer your question.
Happy Viewing.
#3 of 8 Clay-F
Clay-F
  • 230 posts
Posted March 22 2003 - 09:08 AM
I think a big part of veiwing distance is personal perference.
Whats the best part of a movie theatre? Middle mid or middle back? I perfer to sit right smack in the Middle of a theatre, usually.
Anyway, I suggest heading to you nearest Circuit City or equivalent and just sorta test the tv's out. Pace out your distances etc.
#4 of 8 Clay-F
Clay-F
  • 230 posts
Posted March 22 2003 - 09:10 AM
Also I notice I get used to what I'm watching.
Meaning 25" or 27", I usually get involved with the screen and tune out everything else. So couple of inches doesnt really matter to me. I think its the same with most people. As long as the screen isnt abnormally small, you'll probably get used to it.
#5 of 8 Jack Briggs
Jack Briggs
    Executive Producer
  • 16,725 posts
Posted March 23 2003 - 05:49 AM
And instead of directing answers to your query to private e-mail addresses, expect public answers on this public board!
#6 of 8 Larry Pinell
Larry Pinell
  • 8 posts
Posted March 23 2003 - 05:51 AM
You're quite right! I apologize...I'm a little new to this.
Thanks for pointing this out.
-Larry
#7 of 8 joe rizzuto
joe rizzuto
  • 140 posts
Posted March 23 2003 - 09:14 AM
http://www.myhomethe....com/Index.html
viewing calculator here.
let me out!
my dvd list
#8 of 8 Larry Pinell
Larry Pinell
  • 8 posts
Posted March 23 2003 - 09:46 AM
Thank you! This is pretty good.
I guess becuz there's a maximum and a minimum, it goes, to some extent, to personal choice...providing you don't exceed the max.
Cheers!
