Jump to content
Problem with B&K separates
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   Steve Lance
Steve Lance
  • 7 posts
Posted February 23 2003 - 10:23 AM
Hi, I've run into some problems with my 4-year old B&K AVP4090 preap and B&K AV5000 amp. Recently, during 5.1 playback, the unit starting abruptly cutting out. High volume quick bursts of static followed, until I could get the remote to turn off the preamp. It seems to happen after the unit has been playing awhile, but has never happened before. The local dealer has been of little help, but the problem seems to be happening more frequently. It appears to be source independent since it happens with my DVD or XBOX (5.1 adaptor). The problem does go away for a while once the unit it turned back on, but will return.
#2 of 3 OFFLINE   Charles Gurganus
Charles Gurganus
  • 689 posts
Posted February 24 2003 - 12:10 AM
Sounds very similar to what happened to my Sony TA-E9000es preamp. It needs repair (mine was under warranty thank goodness). You are experiencing a power supply failure and/or it sounds like your analog preamp outputs are going as well. I don't think it is the amp. Can you get the dealer to loan you a preamp (even a receiver) to determine if it is for sure the preamp? Just swap out your 4090 with said receiver/preamp to verify the problem. If that fixes the symptoms you have the problem. If not, then the amp may need a look (swap that out next). My money is on the preamp.
Charles
#3 of 3 OFFLINE   Steve Lance
Steve Lance
  • 7 posts
Posted February 28 2003 - 10:30 AM
Thanks. It appears to be the problem that you mentioned and I even got my dealer to cover it out of B&K warranty. Go figure! Thanks
