Jump to content
Preferred way to wire 4 ohm DVC?
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   RayJK
RayJK
  • 131 posts
Posted January 04 2003 - 01:35 AM
Is the a more preferred way to wire up 2 sets of 4 ohm voice coils? Should it be paralleled voice coils and woofers wired in series or series voice coils and woofers wired in parallel? Or does it matter at all?
#2 of 5 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted January 04 2003 - 04:00 AM
You end up with a 4 ohm nominal load either way, so it doesn't matter.
Brian Bunge
RAD Home Theater
#3 of 5 OFFLINE   RayJK
RayJK
  • 131 posts
Posted January 04 2003 - 04:39 AM
Thanks Brian, thats what I thought but sometimes them 'trons don't agree with common sense so I figured I better ask just to be sure.
#4 of 5 OFFLINE   Chris Eriksen
Chris Eriksen
  • 85 posts
Posted January 04 2003 - 05:11 PM
Someone please correct me if I'm wrong here. I always thought that the preferred wiring scheme is 'coils in series, drivers in parallel.' This is due to the interaction that occurs when two slightly different drivers are wired in series. Driver-to-driver variations and uneven loading can result in an induced voltage across the series connection, leading to distortion. This is not a concern when wiring the voice coils of a single driver in series, as the coils are physically coupled.
#5 of 5 OFFLINE   Geoff L
Geoff L
  • 1,702 posts
Posted January 05 2003 - 04:21 AM
In this 2-driver set up. The better way (I would think) is coils in series and woofers in parallel. For just the reasons Chris stated. Don't know how much truth there is to his comment, but it certainly makes sense. At least this way the difference are with the (two drivers) and not all 4 coils at once, if their is any. Rarely do 2 drivers measure exactly the same. Like Chris said, someone else may be able to explain if this would be correct or not when wiring multi drivers with dual coils. Just makes common sense to me, if the load looked for is going to be the same in the end wired either way.
~{ Speak of what you know, listen to what you don't.! }~
