Jump to content
What kind of router bit do I use to cut caps for sonotube?
8 replies to this topic
#1 of 9 OFFLINE   HungLe
HungLe
  • 38 posts
Posted December 16 2002 - 04:45 PM
Hi,
I am building the Adire Aligntment sub. I cant find the upward spiral twist bit at Home Depot, the guy told me it is not very common. What other router bit can I use to cut?
Also how do I get the edge smooth and nice looking? Thanks!
#2 of 9 OFFLINE   Brian Fellmeth
Brian Fellmeth
  • 792 posts
Posted December 16 2002 - 05:31 PM
You can use a straight 1/4 inch bit. The caps should be cut with a circle jig to come out smooth and nice.
#3 of 9 OFFLINE   HungLe
HungLe
  • 38 posts
Posted December 16 2002 - 05:48 PM
i mean like round the edge smooth. Should i sand by hand? i am afraid its gonna be uneven.
#4 of 9 OFFLINE   Hank Frankenberg
Hank Frankenberg
  • 2,573 posts
Posted December 17 2002 - 12:02 AM
Here's the source I use for router bits: MLCS. They have the solid carbide spiral upcut bits:
http://www.mlcswoodw......tml#Anchor 1
You can use a round-over bit to round over one edge:
http://www.mlcswoodw..../bt_rndvr.html
You can use a bull-nose bit to round over top and bottom edges at once:
http://www.mlcswoodw....s/bt_bull.html
#5 of 9 OFFLINE   Jeff Meininger
Jeff Meininger
  • 481 posts
Posted December 17 2002 - 12:23 AM
You can also use a spiral downcut bit. That's what I used for my sub (Hank: is that correct?). I think the spiral upcut will remove sawdust from the groove more effectively and the spiral downcut will make a smoother cut through veneer. I just cleaned the dust out of the groove with a brush... no problem.
#6 of 9 OFFLINE   Hank Frankenberg
Hank Frankenberg
  • 2,573 posts
Posted December 17 2002 - 05:11 AM
Jeff: Yes, you can use either, but I use spiral upcut and they cut plenty smooth. Upcut action pulls the dust up and tends to pull the router down against your workpiece. I use spiral downcut only when going through veneer, as the cut is shearing downward and cuts the veneer edge very smooth.
#7 of 9 OFFLINE   ChristopherD
ChristopherD
  • 106 posts
Posted December 17 2002 - 06:31 AM
My router accepts 1/2" and 1/4" bits...is one more preferable than the other?
#8 of 9 OFFLINE   Pete Mazz
Pete Mazz
  • 761 posts
Posted December 17 2002 - 12:10 PM
I would only buy 1/4" shank for smaller bits. For MDF, 1/2" shanks will not break or vibrate. (Yes, I have broken many a 1/4" bit...not fun!)
Pete
#9 of 9 OFFLINE   HungLe
HungLe
  • 38 posts
Posted December 17 2002 - 03:43 PM
Another question although off topic.
Where can I get the black fabric that goes over my sonotube?
