Yamaha YSP-2200 + Yamaha RX-V571 (1 Viewer)
gustavo
gustavo
friend you can help me?. I bought on amazon Yamaha YSP-2200 Yamaha RX-V571 + and not as connected. Someone can help me?
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Ok, what is your question?
You bought these for two different rooms and you have questions???
Or you thought you needed both?
What?
By the way...you can't use those together.
gustavo
gustavo
What?
The shop at amazon. http://www.amazon.com/Yamaha-IntelliBeam-Projector-16-Speaker-7-1-channel/dp/B006F71UTW/ref=sr_1_6?s=electronics&ie=UTF8&qid=1337786014&sr=1-6
My question is how they connect?
gustavo
gustavo
I need to use them together, I have many peripherals to connect, do you recommend?
schan1269
HTF Expert
Sam
You can't connect them together.
Actually you can, but it is POINTLESS to do so.
You don't purchase a powered speaker set to use with a receiver.
With the YSP 2200, the RX-V571 is redundant.
Mr645
Boca Raton, Florida
Jon
Like others said, the YSP2200 is designed to plug into a TV and does not work wit ha receiver. Send it back and buy speakers, or send back the receiver and use the sound bar
gustavo
gustavo
Gentlemen thank you very much for the replies. Now I want to recommend some good loud speakers 7.1 to accompany the Yamaha RX-V571. I just have to meet a requirement, should be small.
Thank you for your help.
gustavo
gustavo
gustavo
gustavo
Friend how to connect the two? I need to use all entries in the yamaha rx v571
Thanks for your help
acinstallation715
