1. Guest,
XM/ Sirrius for home
Discussion in 'Mobile Phones / Entertainment' started by Nancy_Tice, Jun 14, 2003.
  1. Nancy_Tice
    Nancy_Tice Member
    Jun 14, 2003
    8
    XM radio has a computer unit now (hooks by usb). has anyone tried it yet? I would like to be able to listen in the home and if possible car though the car is not a priority. What's the best way to go? It's hard to sort out what equiptment I need, the xm radio pc unit is inexpensive and sounds easy but I'd love to know someone who tried it.
    thanks so much.
  2. Bob_Hammond
    Bob_Hammond Well-Known Member
    Oct 20, 2000
    47
    I haven't tried it, but you can get more info at www.xmfan.com
    Bob
  3. Nancy_Tice
    Nancy_Tice Member
    Jun 14, 2003
    8
    Thanks I'll go check them out!
  4. DaveBB
    DaveBB Well-Known Member
    May 24, 1999
    792
    If you want user reviews go to xmfan.com. Lots of helpful people over there.
    The xmpcr is a great inexpensive way to get XM if:
    • all your listening will be at home
    • your PC has a good sound setup
    • you travel on business with a laptop and listen through the headphones
  5. Nancy_Tice
    Nancy_Tice Member
    Jun 14, 2003
    8
    yes, I'm looking for a way to hear the music in my office, my computer has excellent speakers. Thanks !
  6. David Broome
    David Broome Well-Known Member
    Jun 2, 2001
    226
    I am basically an XMPCR preacher :)
    I work at home on a computer 10+ hours a day, and I turn my PCR on before anything else. I like it so much I wrote new software for it to make it more flexible.
    For $69 you get all the hardware you need...
  7. Nancy_Tice
    Nancy_Tice Member
    Jun 14, 2003
    8
    thanks!!!
  8. Jeffrey D Smith
    Jeffrey D Smith Well-Known Member
    Feb 19, 2002
    98
    I'm not sure about this, not using sirius, but I believe if you are a customer you can get unlimited streaming audio via the net.
    This way if you have it in your car, you can still access the content inside your house.
    Obviously you need to have at least dsl. I have no idea how well it works, their free sample over the net works well for me though.
  9. Nancy_Tice
    Nancy_Tice Member
    Jun 14, 2003
    8
    I have cable access which is fast and the streaming would work well. something to consider. thanks.
  10. David Broome
    Jun 2, 2001
    226
    I believe you are right, and Sirius offers streaming. The XMPCR, however, doesn't use streaming, and will work perfectly no matter if you are connected to the internet or not (on a laptop in a plane, one guy even said). The sound comes from an audio line out on the PCR, and not teh internet. The computer is just used to turn channels and see everything that is on at once...
  11. Jeffrey D Smith
    Feb 19, 2002
    98
  12. Nancy_Tice
    Nancy_Tice Member
    Jun 14, 2003
    8
    Thanks, I'm having a hard time figuring out which is better, xm or sirrius. I do spend a decent amount of time in the car. Other than a price difference I'm not sure what the "Real difference" is. Is there a good place to read about it? thanks
  13. David Broome
    Jun 2, 2001
    226
    The best placesa for each are XMFan.com and Sirius Backstage.
    I don't think you will be disappointed either way. If you want a solution for house AND car, the Delphi SkyFi would be what you want on the XM side. I'm not sure what the Sirius counterpart is.
    I chose XM, because it was all that was available at the time. I haven't regretted that once since I got it a year ago.
    Read the above message boards, but more importantly, listen to both services. Fortunately, I don't see there being a wrong decision in this, as both services appear to be top notch :)
  14. Nancy_Tice
    Nancy_Tice Member
    Jun 14, 2003
    8
    thanks :) I appreciate all your help.
    Nancy
  15. Crissy_S
    Crissy_S Member
    Feb 5, 2002
    10
    As someone else already said, you really can't go wrong with either one. The difference is in the song selection and amount of commercials. I choose Sirius mainly because I liked what they were playing more. (I had listened to demos of both on the computer for about a week.)
    FYI - You can keep listening to the Sirius stream beyond the 20 minute time limit by switching to another channel before 20 minutes is up and then you start with a new 20 minutes.
    Equipment wise, I think what one has, the other one will come out with. Sirius just got a later start so it's taking a little longer to get their equipment out.
  16. Nancy_Tice
    Nancy_Tice Member
    Jun 14, 2003
    8
    Thanks, I think I will listen to samples and then make up my mind. I really appreciate all the feedback. There is nothing like hearing it from people who actually use it :)
