1. Guest,
Xbox Sound hook up
Discussion in 'Archived Threads 2001-2004' started by Chad Ferguson, Nov 6, 2001.
  1. Chad Ferguson
    Chad Ferguson Well-Known Member
    Oct 31, 2000
    926
    What was the advantage of the Xbox only accepting Optical in their A/V hook ups? I just find it weird that they wouldn't support both hook ups. Anyone know?
  2. Dean Cooper
    Dean Cooper Well-Known Member
    Oct 23, 2000
    975
    3
    Great question Chad. I wish I could figure out the answer. There really is no good answer though, maybe they thought it had a better "cool" factor or didn't want confused customers trying to hook up a coax digital out to an analog audio input. [​IMG]
    Dean
  3. Camp
    Camp Well-Known Member
    Dec 3, 1999
    2,303
    I think coax digital would just confuse a lot of people. To the uninitiated it looks just like any other RCA out. Optical has the advantage of using a totally different plug.
  4. BertFalasco
    BertFalasco Well-Known Member
    Oct 14, 2001
    850
    Exactly, damnit!! What category should I put the optical cable into, I have CD, TV, and CD-R, and a friggin coax. input for DVD, and a digital out.. I'm screwed..
    Any suggestions?
  5. Sean M
    Sean M Well-Known Member
    Feb 12, 2000
    182
    Buy an Optical to Coax converter. I think that Audio Authority makes one and www.copperbox.com should sell it. It's a pretty pricey item in the world on game consoles, but it's probably cheaper than buying a new system/receiver.
    "Experience is the one thing you can't get for nothing." - Oscar Wilde
  6. BertFalasco
    Oct 14, 2001
    850
    Sean, I appreciate it but where would I connect thecoax into? The dvd input? I have a coax. input for DVD, then optical input for CD, CD-r, and TV, and an output for Dolby Digital (probobly for if I wanna connect another reciever..). What do I do?
    -Bert
  7. Sean M
    Feb 12, 2000
    182
    So, your real problem is a lack of inputs. That's even better. Audio Authority makes a neat little video/digital audio switch with both optical and coaxial digital inputs. It's $149 from www.copperbox.com. It even autosenses a signal input and switches automatically. It's a really cool device. I almost wish I needed one. Sure beats upgrading the receiver.
    Edit - Oops. I forgot to give the model number. It's the Audio Authority 1155 (AA1155 at copperbox).
    [Edited last by Sean M on November 07, 2001 at 09:38 PM]
  8. BertFalasco
    Oct 14, 2001
    850
    Thanks alot Sean! I appreciate it
    -Bert
  9. JeffreyH
    JeffreyH Well-Known Member
    Sep 5, 2001
    86
    So if you want digital sound from the Xbox you need an optical input? My buddy has pre-ordered the Xbox and has an older Kenwood with only a coaxial input for digital sound.
    Is he screwed?
  10. BertFalasco
    Oct 14, 2001
    850
    No, he's ok, as long as the Kenwood ahs an optical input because the XBOX has an optical out. You're all good..
    -Bert
  11. JeffreyH
    Sep 5, 2001
    86
    Optical output! That's what I meant to write. No he doens't have anywhere to put a optical cable into his Kenwood.
    So he's stuck with the analog cables.
  12. Wolf Jenkins
    Wolf Jenkins Well-Known Member
    Oct 11, 1998
    162
    Hmm - i think some older AC3 RF demodulators may do this function (some had optical inputs and a choice of coax or optical outputs...) I'll have to look, but I thought my kenwood did...
  13. Chad Ferguson
    Oct 31, 2000
    926
    Can't they get rid of the problem of people mixing the two and go the route that Creative Labs has gone and many followed. What I'm talking about is color cordinating everything. Blue for Optical, White and red for audio, etc...? That why you have more support for hardware and easier install for newbies. Would the Xbox have to change any Hardware at all in the system for it to support coaxil?
  14. Massimo N
    Massimo N Well-Known Member
    Oct 23, 2000
    174
    Bert,
    On my Yamaha RX-V995 I can choose a video output first, the select an audio output, while still keeping the video.
    For example, if I choose VCR2 on the receiver, I'll get picture & sound from that source, VCR&Analog sound. If I then switch (using remote) to CD, I'll keep the VCR picture, but now have the sound hooked up to the CD optical.
    BTW, I'm hooking my XBOX via component straight to the tv, and the optical to any free optical connection on the receiver...probably MINI DISK. This eliminates the need to free-up a video+digital audio slot.
    Cheers!
    Mass
  15. Michael Hudson
    Michael Hudson Well-Known Member
    Jun 13, 2000
    74
    My biggest gripe is the lack of regular connections on the back of game systems Xbox, Gamecube, DC and PS2. I hate the fact that you have to buy special cables to work with game systems. Oh well [​IMG]
    Michael
    Video Game Tracker
    DVD Tracker
    DVD Profiler
    CD Tracker
  16. Chad Ferguson
    Oct 31, 2000
    926
    michael, I'm not quite sure what your refering too by that but if your wondering if Xbox comes with a regular hook up it does. It will come with composite video and l/r audio hook up.
  17. Michael Hudson
    Jun 13, 2000
    74
    What I am saying is for example my first PS from 95 has normal audio video outs on the back red white and yellow. It came with cords but you could use any. The new PS2 has a toshlink out that you can use any toshlink instead of one made just for the XBOX. I understand the units all come with video and audio outs I just with the back looked like a normal piece of AV gear not needing special items that cost more. [​IMG]
    Michael
    Video Game Tracker
    DVD Tracker
    DVD Profiler
    CD Tracker
  18. Camp
    Dec 3, 1999
    2,303
    Which is exactly why they use "special" cables. It's a source of revenue.
  19. Graeme Clark
    Graeme Clark Well-Known Member
    Jan 5, 2000
    2,181
    Of course if it came with every connection available built right into the machine, we'd have to hear certain people complaining about paying for things they won't use.
  20. Camp
    Dec 3, 1999
    2,303
    [​IMG]
