Tom Brennan
- Nov 1, 2000
- (see above)
Michael----I've seen articles on even bigger built-in basshorns. Check this out www.scrounge.org/speak/burwen/index.html
So from that aspect, jewelry might be an accurate description, since the aluminum is strictly a "looks cool whiz bang" thing, not an inherently superior material.
I would say that is innacurate. Because Aluminum is very non-resonant, it eliminates distortion.
Subwoofers in general create bass through distortion and cabinet resonance. The Krell goes against that logic, and creates its bass through moving soundwaves pressurizing the listening environment. Not just making it's own enclosure vibrate.
But for thoseof us thatdon't have 30k, the best sub I have ever owned is... http://www.martinlogan.com/descent_speaker.html
Say what
There are some pretty bad commecial sub out there I'll agree. But I don't think even the worst one would produce more bass from cabinet resonance then from the driver and/or port/PR. And certainly not from distortion.
Good sonotube, MDF or void free ply enclosures (with the non cylinder ones properly braced) will sound just as good as an alluminum enclosure. The alluminum enclosure won't make an noticeable difference, if any difference at all.
I'd also say alluminum is very resonant, just at frequencies significantly higher than what subwoofers play.
The Descent I'm sure is a very nice sub, but still lacks output in the last octave and costs too much (the Krell is just ridiculous, the Descent is not ridiculous, but still too expensive).
Have you heard the descent? It is rated in the owners manual to 20hz, but believe me, it plays lower. Costing too much is completely relative. It costs too much for you, maybe. Audio is like cars. If all you are used to seeing and driving is Toyotas, then a Ferrari might seem a little steep, but the performance is absolutly there. Thats how it is for me. Just because most HT'ers are spending a couple hundred bucks per component, does not mean it is the best, and everything else is too expensive. Sure, there is a lot of audio gear out there that is overpriced, but some of it is worth every penny.
I have owned many subs, and the Descent is at the top of my list. I previously owned the similarly priced Velodyne HGS-15, and I loved it too. Why did I get a different sub? Well, this a hobby to me, and the defenition of a hobby is something you start with the intention of never finishing.
