1. Guest,
Wives, girlfriends, and home theatre
Discussion in 'Beginners, General Questions' started by RAMBOZOTHECLOWN, Nov 14, 2013.
  1. RAMBOZOTHECLOWN
    RAMBOZOTHECLOWN Active Member
    Nov 12, 2013
    38
    Yeah we had it that way once, you can't see it, but there's a green leather chair down under the John Wayne picture. Yeah it is a nightmare. Haha!!! Another thing you can't see is behind the sectional is that the living room is recessed about 6-8 inches below the dining room so the sectional cannot move backward at all, as it's against the step.
  2. RAMBOZOTHECLOWN
    Nov 12, 2013
    38
    It is plasma. Also a little worried about putting too many concrete anchors in the brick.
  3. RAMBOZOTHECLOWN
    Nov 12, 2013
    38
    I really appreciate your help by the way.
  4. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,037
    894
    Chicago-ish/NW Indiana
    Sam
    There are many ways to mount a TV to a brick wall. You could even get high tension wire(like used for really heavy mirrors and paintings)...
    1. Put two screws in the top of the VESA and twist the tension wire around it...
    2. Rubber stop the bottom two VESA.
    Essentially do the same you've already done with the mirror. High tension wire is available at any fabric/framing store.
  5. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    But....how much heavier is the TV than that mirror? I almost bet they weigh about the same.
  6. RAMBOZOTHECLOWN
    Nov 12, 2013
    38
    Sounds like my best option. I could use the existing anchors to do that too.
  7. RAMBOZOTHECLOWN
    Nov 12, 2013
    38
    Gotta look that up in the tv's specs.
  8. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    OK, maybe that mirror isn't hanging like I thought it was...
  9. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    By the way, I've hung TVs from rafters before using wire. Did a visual presentation setup in an art gallery. The TVs floated 9' up at roughly 30 degree angles(16' ceilings...with beams at 12')
  10. RAMBOZOTHECLOWN
    Nov 12, 2013
    38
    TV is 45.6 lbs
  11. RAMBOZOTHECLOWN
    Nov 12, 2013
    38
    The mirror was mounted using lead concrete anchors and a wire I think. It's been there for quite awhile.
  12. FoxyMulder
    FoxyMulder 映画ファン
    Sep 14, 2009
    5,236
    1,612
    Scotland
    Malcolm
  13. RAMBOZOTHECLOWN
    Nov 12, 2013
    38
    The surrounds are fine it the left front that's the offending speaker.
  14. FoxyMulder
    FoxyMulder 映画ファン
    Sep 14, 2009
    5,236
    1,612
    Scotland
    Malcolm
    You could buy some front ceiling speakers too with tweeters you can point, some white speaker cable, it would make everything look better, it's a compromise but no more so than it is already.
  15. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    The only issue here is the plugs on this AVR are proprietary.
    Not really a huge deal(get some banana plug male/females)...but it isn't simply swapping speakers.
