Wireless Headphones won't work with home theater (1 Viewer)
babydoc123
Stacey
Hi everyone,
Iecently bought a pair of wireless headphones to use with my home theater system but I am having a problem getting them to work with my Blu Ray player. My components are as follows:
Home Theater: Panasonic SC-BTT350 (receiver is in blu ray player)
TV: Toshiba 55HT1U
Cable Box: Motorola 7232-P2 (Verizon DVR set top box)
Headphones: Sennheiser RS 120
When I plug the headphones into the cable box and mute the TV I get great sound. However, when I try to use the headphones with my DVR player I can't get any sound at all. I have tried plugging the headphones into the TV directly or into the DVR via the Auxiliary jacks but nothing works. Any suggestions? I have read things about using headphone amplifiers and/or connecting a DAC between the cable box and the DVR but I'm not sure which way to go.
Any help would be greatly appreciated. Thanks!
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
If that Panny can't send the audio to the TV, you are out of luck with any headphones.
There should be a setting to send the audio to the TV.
With the TV you'll need...
Optical to analog adapter (http://www.amazon.com/Digital-Optical-Toslink-Analog-Converter/dp/B004C4WPXA/ref=sr_1_1?s=electronics&ie=UTF8&qid=1347063137&sr=1-1&keywords=optical+analog+converter)
babydoc123
Stacey
Ok that's great - but how should I connect the converter? And where should I connect the headphones?
AlohaTiger
