Ramesh Kumar
- Sep 27, 2006
- Ramesh Kumar
Hi,
Will the older class AB amps work well to support the dynamic of Master Audio and Dolby True HD ?
I would like to know if a class AB multi channel power amp (example Sherbourn, Anthem or Parasound) will work well with a pre-processor that supports Master Audio and Dolby True HD (example Rotel RSP 1580 or RSP 1582)
Most of the power amps these days are Class D for reasons of efficiency.
Is the class D got anything to do with audio dynamic that comes the above audio formats.
The primary question is of ability to truly reproduce Master Audio and Dolby True HD with class AB
The secondary question of the matching between the above pre and power amps.
