1. Guest,
Which Receiver? Older Marantz SR 7002 or Newer Yamaha RX-V2065 ???
Discussion in 'AV Receivers' started by donaldla, Sep 24, 2010.
  1. donaldla
    donaldla New Member
    Sep 24, 2010
    4
    Can someone recommend which receiver and why? I understand Marantz is quality. Want 2 HDMI outputs one for my Panasonic Plasma TV and the other for my HC1500 Mitsu projector. Also recommendations appreciated. Budget $700 keep in mind.
  2. gene c
    gene c Well-Known Member
    Aug 5, 2003
    5,838
    47
    Bay area, Ca
    Gene
    People around here really like Audyssey room correction. Yamaha has their own version, YAPO, but Audyssey seems to be just a bit better than the rest.
    Marantz is known for their very musical sound, for those who feel there is a difference, and strong amp sections and over-all build quality. The biggest issue with the 7002 (and the 8002) is it won't apply Audyssey to any signal input via HDMI. Apparently it doesn't have enough processing power . This means you need a BluRay player that can decode the new HD audio formats and sends them out via LPCM. Then, even if connected via HDMI the 7002 will apply Audyssey (since the 7002 won't be decoding the signal there's enough processing power to apply Audyssey). All other components would need to be connected with an optical or coax digital cable to enable Audyssey. I don't have first hand experience with this issue but this is what I've read.
    I've never owned a Yamaha receiver but the other Yamaha devices I've owned I was very happy with.
  3. donaldla
    donaldla New Member
    Sep 24, 2010
    4
    Thank you Gene, went with the Marantz.
