1. Guest,
What distance should be between ports and speaker/walls?
Discussion in 'Home Theater Projects' started by David Lorenzo, Aug 5, 2006.
  1. David Lorenzo
    David Lorenzo Well-Known Member
    Dec 12, 2002
    198
    I am building a box and I was wondering what the rule was for the distance between the speaker, port, and walls.
    I am using a 4" port so I remember hearing that there should be 4 inches from the front and back of the port, is that right?
    Also how much clearance should there be around the port and speaker.
  2. ThomasW
    ThomasW Well-Known Member
    Nov 6, 1999
    2,282
    The port should be it's diameter or more from any boundry
  3. Blaine_M
    Blaine_M Well-Known Member
    Mar 11, 2004
    400
    Probably more than 4 inches I would think. I built a pair of GR Research AV/3 towers and was told to get them 3 feet or so from the wall.....which I can't quite do, but I'm close.
  4. ThomasW
    Nov 6, 1999
    2,282
    I think he's asking about the spacing of the port inside the box, not how far the box should be placed from the walls of the room
  5. Blaine_M
    Mar 11, 2004
    400
    Ah, I see, that I have no knowledge of!
